× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN4220 Max Capacity?
GregP
Follower
I'm considering a RN4220, but need 72TB raw capacity (12x6TB).  I'm confused whether this configuration is supported.  There is conflicting information.
When going through the nas filtering process on netgear.com, this model appears when I filter by 72TB.  But the spec sheet clearly lists 48TB as the max.  But the hardware compatability list includes several 6TB drive models.  Lastly, the biggest pre-populated model is 48TB (12x4).
So.... can I buy a diskless 4220 and fill it with 6TB drives?  Thank you.
Message 1 of 3
mdgm-ntgr
NETGEAR Employee Retired
Re: RN4220 Max Capacity?
Yes. I would recommend using a dual-redundant RAID level such as RAID-6.
You can buy 6TB disks from the compatibility list.
The spec sheet you saw would have been written before 6TB disks were available.
Message 2 of 3
itsjasper
Luminary
Make sure that you buy a v2 RN4220 if buying a second hand unit - the v1 units have a 2TB drive limitation in bays 5-12.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3703 views
  • 0 kudos
  • 3 in conversation
Announcements
