Mbell93536
Jun 12, 2017Aspirant
AC1450
My router keeps disconnecting and connecting to my WiFi
Approximately 6 cycles per hour
Thought it may be firmware but have version 1.0.0.22
Any thoughts? Just added Amazon echo, echo dot, ecobee 3 thermostat, 5 smart lights, and wireless irrigation panel- is that too much for this router?
- William10aMaster
Model number located on the bottom of the router on a label should like r7000 and may have v2 or so on the v quals version the 2 is which version it is.
- Mbell93536Aspirant
Couldn't find a "V" anywhere.
- William10aMaster
If there is a model number but no v with a number after it is a version 1 then ok what is the model number?
Ac1450 is total rated wifi speed for bot the 2.4 ghz and 5ghz band together.
This link may help you find the model number https://www.netgear.com/support/
