mbobich
Apr 30, 2021Follower
Android Nighthawk App not connecting to wifi.
I have gone through the setup process several times, and each time I get the message, "Issues connecting with "MyWifiNetworkName" even though that is the exact network I am connected to. I am on android, if that helps. At this point, it feels like I spent $80 on a product that's been bricked by an app that doesn't work.
- wiredbunnyAspirant
I am also experiencing issues connecting to my extender through the App using Android. Green light on Extender but NOT seen as a connection. I have rebooted, reset, updated and downloaded so many times that I don't know which router, extender, modem, or model I am referring to!!!!!!
- Christian_RNETGEAR Employee Retired
Hello,
You may try using a web browser and visiting routerlogin.net to setup your router.
Christian
