Orbi WiFi 7 RBE973
Reply
Application connection
HeZe
Follower
I have a Netgear Nighthawk M1. I use it as a mobile WiFi and it works nice.
My SIM card is with Swisscom (Switzerland).
On my iPhone, I have the application Netgear Mobile and everything seems to work fine (but I do not use all the possibilities).
On my iPhone, I have also the application Nighthawk Netgear but I cannot connect it with the mobile router.
How can I do it, is it necessary to do anything else ?
Do I also need to do anything on the Internet site of Netgear ?
Thank you for your answer and best regards,
H. Zender
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
Re: Application connection
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 679 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
