Reply
Armor not installing
Paultuk
Follower
My router has the latest firmware installed  1.0.4.52  and i have  uninstalled and reinstalled the  nighthawk app on my phone several times ,  I have also done a new setup from my phone , but no matter what i try   i cannot get armor on to my router , All the instructions i see  tell me is it should be automatic after doing a new setup, yet i get nothing  any ideas what i am doing wrong ?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Re: Armor not installing
@Paultuk wrote:
... no matter what i try   i cannot get armor on to my router , All the instructions i see  tell me is it should be automatic after doing a new setup, yet i get nothing  any ideas what i am doing wrong ?
A couple of points, where are you looking for Armor?
Try the browser graphical user interface (GUI) and see if you can activate Armor there..
While you are in there apply the latest firmware:
R8000 Firmware Version 1.0.4.56 - Hot Fix | Answer | NETGEAR Support
As a hotfix, it probably hasn't arrived on the firmware FTP server.
Secondly, Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might do better to try there.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 832 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
