Orbi WiFi 7 RBE973
Reply
Can't Coonect to Parental Controls via Genie PLEASE HELP!
Quintin89
Follower
Hi there I have the following router Negear DGN2200v3 and I did connect with parental Controls 1 Week back but now its not working trying to put the user name and password in then it just stays there. This is what its saying " There was an error signing in, please make sure you're connected to the internet and try again"
I have been trying to sign in for 3 days now. . .. . . I reinstalled Genie still does not work. I also have Genie installed onto my Samsung Galaxy S5 but it also does not want to work.
I Can send a screenshot if needed please help me!
If i log onto my OpenDNS account on the internet it works fine. everything work in Genie its just the Parental Controls thats giving problems.
Regards
Quintin
Message 1 of 8
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Can't Coonect to Parental Controls via Genie PLEASE HELP!
Hi @Quintin89,
This has already been reported and is currently being looked at. I will be sending an inquiry to Engineering about this and provide an update on this thread.
Dexter
Community Team
Message 2 of 8
All Replies
DexterJB
NETGEAR Moderator
Hi @Quintin89,
Dexter
Community Team
Message 2 of 8
This is marked as "Solved" but when i click on the solution link it just points me to a tech saying it has been reported before and they are working on it. Not really solved...
Message 3 of 8
welcomejt
Initiate
I am having the same issues.  I have seen posts regarding throughout this year.  It doesn't seem that Netgear sees this as a priority.  Time to switch router.
Message 4 of 8
DexterJB
NETGEAR Moderator
Hi @unhappy_buyer,
We apologize for the inconvenience. This is currently being worked on by Engineering. In the mean time, you can try using an iOS or MAC OS X device for you to log in to your OpenDNS account using the NETGEAR Genie and manage your LPC settings.
Dexter
Community Team
Message 5 of 8
SmithJO
Same problem:
OSX (v10.11): " There was an error signing in, please make sure you're connected to the internet and try again"
IOS (v9.1): Genie either exits or crashes.  Genie comes up, Traffic Meter works, Wireless Settings works (but is rather useless), Network Map goes to 'Loading Network Map' dialog and proceeds to endlessly spin...  Parental Controls goes to 'Loading Parental Controls' dialog, and then promptly exits...
OpenDNS support webpage has an ongoing (since April 2014) stream on this topic: https://support.opendns.com/entries/33173850-I-cant-get-the-Parental-Control-to-accept-my-login
Scrolling down a year you get the following:
"Even logged out and back into the genie.  On the routers web access page, the parental controls button doesn't even work."
What exact Netgear router model do you have?  Is it supported by the Genie app at all?
http://kb.netgear.com/app/answers/detail/a_id/24686/
If not, use the older Management Utility and User Utility: https://www.opendns.com/downloads/
"OpenDNS is monitoring this forum but not taking responsibility for their product."
Oh, I'm confident that OpenDNS take every responsibility for their products.  But Netgear routers do not count as such as the firm name "Netgear" already says.
March 19, 2015, 10:31
Message 6 of 8
SmithJO
And while this gets me further into the process (I can now register my network on the account), I'm still not past the Genie login issue...
Message 7 of 8
DexterJB
NETGEAR Moderator
Hi @SmithJO,
You should be able to login to your OpenDNS account through the NETGEAR Genie and manage your LPC (Live Parental Controls) settings.
Dexter
Community Team
Message 8 of 8
Discussion stats
  • 7 replies
  • 6914 views
  • 5 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
