Orbi WiFi 7 RBE973
Reply
Compatibility Issues
CReynard
I just purchase the netgear AC1900. I currently and using the hitron CDA3-35 modem. For some reason or another it's not getting the internet to the router to project the wifi. Just wanting to know if it's a compatibility issue and need to upgrade the modem.
Message 1 of 4
netwrks
Master
Re: Compatibility Issues
For clarification, exactly what AC1900 do you have? What is on the box?
Message 2 of 4
CReynard
The nighthawk smart wifi router
Message 3 of 4
netwrks
Master
Power off your modem. Wait about 5 minutes, then power your modem back on. Wait for you modem to come back online, then ***power on the NG router. Run Internet Set up Wizard (page 22 router manual). ***Before you power on your NG router, ensure you have a Ethernet cable (min CAT5e / CAT6) cabled from WAN / Internet port from the NG router, to the Ethernet port on the Hitron modem. Also, Ethernet cable a laptop to a LAN port on the NG router.
Don't forget to change the default router login password and default wifi passphrases.
Router manual
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3381 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
