- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Device manager on iOS not working ('No Device Found!)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just noticed this problem today. Everything is connected, but on the Nighthawk App, when I select the Device Manager, it says that 'No Device Found' although everything is working.
I checked the routerlogin.net page, and it lists the 20 devices that are connected. Problem seems to be with the iOS Nighthawk App.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem was the iOS app. Once that was updated and I downloaded the latest update - then it worked.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Device manager on iOS not working ('No Device Found!)
Facing exactly same issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same issue. Please fix ASAP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sniff around and you will find many many reports of the same thing.
Lots of different hardware hit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This feature worked initially when I installed the system a few weeks ago. Either a firmware upgrade or an iOS app upgrade has rendered the "connections" invisible. I can no longer see the 10-15-20 devices I have connected via wifi. Annoying.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi JamesENicholson,
Welcome to the community! May you provide the following info.
Product Model:
Firmware Version:
App version: (iOS/Android)
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
R7450 My Netgear App has bugs, 1 can NOT connect remotley, 1 can change icons in the DM
We installed the newest ver app and ver in the router still not working
Do I need to take the router back?R7450
- Mark as New
- Bookmark
- Subscribe
- Permalink
Who knows what your problem is?
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one, especially in a Solved discussion.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Device Manager, no devices found..
IOS - would greatly appreciate some guidance.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Erikruss,
I would recommend reinstalling the Nighthawk app and rebooting your router.
Christian
