- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Genie Web UI WNDR3700v3 not showing correctly
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm curious if anyone has seen their UI do something like this before. More importantly if anyone knows how to correct it that would be great. With iut like this some of the functionality isn't working properly. I have to open the wireless setup in another window to even get access to it.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
By chance do you have any Kaspersky 2017 security products installed? I know the 2017 product line has casued this kind of webGUI display issues just like this. Disabling the Kaspersky 2017 product does not work to correct the issue, you end up having to uninstall the Kaspersky product and the webGUI display issue is no more.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Genie Web UI WNDR3700v3 not showing correctly
I actually installed those about 2 days ago. I guess that's what I get for finally getting away from Norton.. hah.
I guess I'll have to hunt through the Kaspersky forums to see if I can hunt down a fix.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you do not have Windows 10, but an older version of Windows OS, you can use you Kaspersky license and install the 2016 product version (see http://usa.kaspersky.com/downloads/software-upgrades/). The version 2018 product line is due out very soon. I installed the 2018 pre-release build version of Total Protection, and did not have the issue in the 2018 version.
