Orbi WiFi 7 RBE973
Reply
How to disable Parental control
djmc117
Tutor
How do I disable Live Parental Control on my NightHawk R7000 router?
I am trying to chang emy DNS settings and I'm told I have to disable LPC.
There doesn't appear to be any option to disable this from the Netgear Opendns LPC account.
Thanks,
Declan
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: How to disable Parental control
Hi @djmc117,
1. Did you previously setup Live Parental Controls?
2. Have you tried using the Genie app (Android, iOS, desktop)?
3. Have you tried disabling it via https://netgear.opendns.com/sign_in.php?
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @djmc117,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @djmc117,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 6001 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
