RiverTerrace's avatar
RiverTerrace
Follower
Nov 30, 2022
How to reset nighthawk app when forgot secret questions
  • You don't reset the app. You factory reset the router. At the back there's a Reset button/hole. Press in while router is on for 5-7 seconds
