Reply
I have a C700v2 need help with app
Slr8929
On the nighthawk app when I go to devices each device has a link rate what does that mean? Is that the wifi speed that they are receiving from the router?
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 5
Accepted Solutions
Re: I have a C700v2 need help with app
Link Rate and Transfer Speed | Answer | NETGEAR Support
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 5
All Replies
Guru
That's their negotiated link rate between router-----device. It can change based on distance/interference.
And it gives you a rough idea of how fast the connection is because usually actual throughput speed is roughly 55-65% of link speed.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
Slr8929
I have a device on the app that says the link rate is 144Mbps does that mean that is the amount of speed it’s using?
Message 3 of 5
Guru
Thats its connection to the router, not the amount of bandwidth used.
Message 4 of 5
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 948 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
