Orbi WiFi 7 RBE973
Reply
Live Parental Control - Not working with R7000
NetRags
Tutor
Hi Team,
We are facing an issue with LPC - OpenDNS account. Whenever tried user defined password always getting an error message as "Incorrect Password". But when tried with @@@@@@@@@@Pd1 it worked. But on the next screen getting an error message "There is no NETGEAR Router is associated with this Router" thereon unable to proceed. When checked with NETGEAR support they replied to wait for the next firmware release.
TSH done so far..
#1. FV update / downgrade
#2. Hard reset
#3. Uninstalled / Reinstalled NETGEAR Genie
#4. Tried with different PC / OS
Is there any other TSH missed out?
Is this issue occuring with one particular Router or will all the devices?
What is the work around?
How long it takes for NETGEAR Engineering Team to come up with the update?
Thanks,
NetRags
Message 1 of 3
DexterJB
NETGEAR Moderator
Re: Live Parental Control - Not working with R7000
Hi @NetRags,
Can you try creating an OpenDNS account again and login through the NETGEAR Genie program? It should be working now.
Dexter
Community Team
Message 2 of 3
storm1985
Prodigy
@NetRags if you are using Windows Genie (2.4.16) set password minimum of 13 characters and contain one (uppercase, lowercase, number and special character)
Minimum of 8 char password requirement is working on iOS (2.4.22) and Mac OS (2.4.10)
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4192 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
