Balaclava's avatar
Balaclava
Follower
Dec 05, 2019
Model R6350
How do I download the nighthawk app for a desktop. Is this machine only for a mobile device or can I use it on a desktop?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Balaclava, welcome to the community! The Nighthawk app is available only for mobile devices on both iOS and Android. It does not have a desktop equivalent.
    Dexter
  • michaelkenward's avatar
    michaelkenward
    You can use the desktop genie for your operating system.
    If you want the desktop genie for Windows start here:
    genie Landing Page | Apps | Discover | Home | NETGEAR
    You may have to dismiss an annoying pop-up that tries to push a mobile app down your throat.
    It is a pity that Netgear is trying to force us all to use its crummy mobile apps. Some of us still use PCs.
  • I have been using Night Hawk Router Model R6350/ AC1750 for more than 2 years and mange the device list by using IOS app.
    Recently the device list is appears as not found in the app and I reinstalled app but no use.
    Logged in to webiste and it shows the device list but the problem is with IOS app.
    May I know how to solve this problem
    Thank you inadvnce.
