Reply
NETGEAR Genie User Manual / Help
alphadogtucker
Follower
:mad: Somebody please tell NETGEAR that I'm ticked about them distributing the Genie software without a User Manual, Help function, or at least a category of its own on the Forum.
:confused: At the bottom of the Internet screen of the Genie application, I see a slider bar calibrated in 1Mbs steps, from 1Mbs to 20Mbs. Alongside it, I see a checkbox labelled High Traffice Threshold. I can't see that they make any difference. What do they do?
Smiley Wink Apart from that, Genie installed easily and seems to work great.
Message 1 of 2
jmizoguchi
Virtuoso
Re: NETGEAR Genie User Manual / Help
Contact support via portal at my.netgear.com for any direct question if you like to ask
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 15815 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
