- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Genie Does not work to bypass parental control
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have installed Netgear Genie on MAC and when I goto Parental Control I am not able to move forward as I want to add ByPass account. I get below message. I am connected to internet using this router. I have added bypass account on my IPhone but it does not work on my MAC and iPad. I have tried to connect to router using direct cable. Router firmware is V1.1.00.15.
MAC Version is 10.10.3
Checking router firmware
Were making sure you have firmware that supports Live Parental Controls.
You dont appear to be connected to the internet. Please connect to the internet through the Netgear router and try again.
Appreciate if someone can help on this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Genie Does not work to bypass parental control
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I have changed the IP Address of the router to 192.192.192.1. I am not sure why would it work fine on my iPhone but not on MAC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@varsur wrote:I have installed Netgear Genie on MAC and when I goto Parental Control I am not able to move forward as I want to add ByPass account. I get below message. I am connected to internet using this router. I have added bypass account on my IPhone but it does not work on my MAC and iPad. I have tried to connect to router using direct cable. Router firmware is V1.1.00.15.
What I did to get things working was first create an OpenDNS account and configure two Bypass accounts from there. Then I used Genie to setup Parental Controls and used my login for OpenDNS then Genie happily setup everything else.
I suggest you create an OpenDNS account first and create your Bypass accounts, then use Genie to setup Parental Controls.
Go here to create OpenDNS account: https://www.opendns.com/
Go here to log into Netgear.OpenDNS to create Bypass Accounts: https://netgear.opendns.com
Use the sign-in from OpenDNS to log into netgear.opendns.com
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
