- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Genie for iPhone is getting router not found or not supported since 10/5/16 upload
- Mark as New
- Bookmark
- Subscribe
- Permalink
Today is 10/10/16. The Netgear genie I'm running is 2.4.3 Dated 10/5/16. My router firmware version is V1.0.0.52. BTW the Windows Vers 2.4.32 works okay on Windows 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Genie for iPhone is getting router not found or not supported since 10/5/16 upload
I only used the app for local management as I didn't enable remote management feature. I also found the new IOS app no longer discover my router. I found a workaround by I select "Enter router's IP Address manually" and type in the IP address of the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you so much! Manually inputting the IP address worked! Never had to do that before, but the Genie app on my iPhone is now working again. You are a superstar!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I didn't get a chance to try manually input of IP address. The recent update fixed the issue.
I received an email from Netgear support asking me to remove the app and reinstall it.
It worked but then problem came back again. Also it wiped out all the names i had for my devices 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
