Orbi WiFi 7 RBE973
Reply
Netgear genie not compatible
Sticksian
Follower
Hi
I have set up my new wn3500rp and it seems to be all good. The only Isuzu is when I tried to connect my android phone to stream music using netgear genie. The instructions state that you can use netgear genie but when I try to connect the app tells me that the 'router' is incompatible.
It works find with my ipad but I would also like to use my android devices as well.
Any thoughts?
Message 1 of 2
jmizoguchi
Virtuoso
Re: Netgear genie not compatible
Contact supports with the issues via portal
My.netgear.com
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 11045 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
