Orbi WiFi 7 RBE973
Reply
Nighthawk 7000
Dogdad7
Nighthawk 7000
Curious..I saw my router was set on something other than “connected locally” ..  don’t remember what exactly it said but I hit the connected locally option which is now the setting. I don’t see the option of what it was set on. Anyone know what or how to change this?
Message 1 of 3
Guru
Re: Nighthawk 7000
Try disabling Anywhere Access by selecting the cloud in the circle icon, select Settings, then select Anywhere Access. Slide the button to disable this feature. Then check and see if local access is seen in the Your Products list as a Local Connection.
Message 2 of 3
Dogdad7
Re: Nighthawk 7000
Thanks so much..does it matter which one to choose or have any benefit one over the other?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 638 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
