Orbi WiFi 7 RBE973
Reply
Parental Controls and Custom Levels
JTK
Is it possible to define more than 1 custom parental control profile for the R7000 Nighthawk?  I tried changing the predefined ones (low, medium, high), but the changes don't seem to be saved.
Message 1 of 2
DexterJB
NETGEAR Moderator
Re: Parental Controls and Custom Levels
Hi @JTK,
You can only configure a single custom setting for the Parental Controls feature on your NETGEAR device. However, you can use different filtering levels on individual devices using the NETGEAR Genie desktop app.
Dexter
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4117 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
