- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Parental bypass controls - R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have enabled my parental controls, downloaded the Genie app and change settings to so my devices will bypass the controls. Even with my devices using the bypass, I am still blocked. Let me give a specific.
I created a blacklist and whitelist in my parental control settings. I want to block YouTube. I have downloaded the Genie app, activated the bypass account on specific devices, and still am blocked from YouTube. I have checked the Network Map on the device in question and on my laptop and can see that the devices in questions have parental controls enabled with the bypass login engaged.
I have read some of the others comments and tried the following:
Deleting and reinstalling Genie
Disabling Parental Controls and Enabling again
Refreshing my settings - Parental Controls, Wireless, and Router Settings
Rebooting my Router
None of these have worked.
I am not a computer novice and have tried to research the comments but to no avail. What do I need to do in order to have this work properly. Any suggestions would be helpful.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parental bypass controls - R7000
Hi @LHL711,
Please make sure that the DNS settings of the devices are set to be obtained automatically from the router. Also, make sure that when LPC (Live Parental Controls) is enabled that the router's DNS are set to the OpenDNS servers of 208.67.222.222 and 208.67.220.220. If not, you can have them manually set.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
My DNS setting were on automatic but I manually changed them to the ones you suggested. After I did that, my Mac was able to bypass but my phone and iPad was not. It seemed that my iPad kept logging me out because it made me log in to the genie and do the bypass login every time.
Also, when I would check my network. Map and click on the device to check status, it would show the bypass login was engaged. Again, that was. It the case for the devices in question.
I ended up disabling the parental controls until I have more time to play with it. Any more ideas, thoughts, or comments to help further with this would be greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
