- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 Won't Save Parental Control Filtering, can't login through genie app
- Mark as New
- Bookmark
- Subscribe
- Permalink
R7000 with V1.0.9.26_10.2.31
Windows 10 Genie App Version 2.4.52
2 issues:
1. Single device parental control filtering doesn't actually save. It acts like it does, but always defaults back to 'default level on router'. This means I can't change parental controls per device at all. I've tried with windows app as well as iPhone app, it just doesn't save.
Other issue is, after latest R7000 firmware update and Genie app update, I can no longer log into OpenDNS through the genie app. First it wouldn't let me log in at all. Now, after complete reset of router, it lets me login, but doesn't actually save settings or filter content. When I go to bypass login, it shows: "failed to get bypass account information due to network problem".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 Won't Save Parental Control Filtering, can't login through genie app
Having the exact same issue as well. Is there a fix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My solution was switching to the Disney Circle app instead of OpenDNS. It actually works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Of course that's what they want us to do since so much money was used to advertise the service. All I use the parental controls feature for is to take advantage of OpenDNS's ability to block phishing sites with the Minimal blocking category. I have no reason to use Circle so this issue is incredibly frustrating for me.
