Orbi WiFi 7 RBE973
Reply
RAXE450 anywhere access does not work using IP Passthrough enabled on AT&T BGW320
1yonger
I have AT&T fiber through BGW320 device.
I installed RAXE450 and enabled IP passthrough on the BGW320.
Remote access using Nighthawk anywhere access does not work with IP passthrough. No issues locally.
I suspect app cannot see the router with IP passthrough.
Any workaround on this or is this a permanent annoyance with BGW320 (IP passthrough)?
Message 1 of 2
Re: RAXE450 anywhere access does not work using IP Passthrough enabled on AT&T BGW320
What is the firmware on the RAXE450? Which app? (Android? iOS?)
In what way "does not work"?
AT&T seems to have the same strategy as BT in the UK, it supplies gateways that are impossible to configure as users might like. No true bridge mode.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 495 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
