FarAfield's avatar
FarAfield
Follower
Sep 23, 2015
Remote Management through OIS Genie app, router not registered
I am trying to set up remote management on an R7000 and am having troubles, I think on Netgear's end.
I logged into the router via the webpage, turned on remote management for any user (I will dial this down once I get it working) and saved the settings.  I also made sure my router was registered with Netgear.  When I try to log in remotely from Genie on my iPad or iPhone, the list of regsitered devices is blank and I get the message "no router is registered."  Any thoughts?
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi FarAfield,
    Have you tried using a computer to log in remotely?
    Dexter
    Community Team
