Orbi WiFi 7 RBE973
Reply
Router not connected
RickK726
Follower
Recently, I have not been able to connect to my nighthawk router R9000 or my NETGEAR extender EX8000 using the nether genie or nighthawk app on my iPhone 6s I also can’t connect using my MacBook Pro with Mojave ver 10.14.1. It says my router is not connected, but if I put in the routers IP address, it will show it is connected and all my devices are connected. I checked for firmware updates, but doesn’t seem to be connecting to NETGEAR server. Any help would be greatly appreciated.
Model: Genie|Desktop Mobile and Product Setup Genie
Message 1 of 3
DexterJB
NETGEAR Moderator
Re: Router not connected
Hi @RickK726,
Welcome to the community!
1. What is the firmware version of the router and the extender?
2. Have you tried re-installing the apps?
3. What version of the app/s do you have installed?
4. Was working before?
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @RickK726,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1140 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
