- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router not getting connected Netgear Nighthawk WiFi 6 System (MK63) - AX1800 Router with 2 Satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought a nighthawk mesh router with 2 satellites and have connected them to my router. The light turned blue for all of them. I have downloaded the nighthawk ios app but the router says it is not connected. I connected the nighthawk router to modem but it is not able to detect. Any tips on how to resolve it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router not getting connected Netgear Nighthawk WiFi 6 System (MK63) - AX1800 Router with 2 Satel
what modem/gateway/router are you connecting the mesh system to?
If its has its own routing capabilities it causes a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
Simpliest fix? put the mesh system in access point mode. but it does disable some features
otherwise you can put your current gateway in passthrough/modem only mode
or the netgears IP address into your current routers DMZ
- Mark as New
- Bookmark
- Subscribe
- Permalink
As @plemans says, a lot depends on the modem you refer to. Is it a modem or a modem/router?
Even if it is a straightforward modem, line Netgears' DM200, it may have a "router" mode that you should disable.
You also need to follow the instruction carefully, doing things in the correct order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
If your modem really is a modem/router, then it may be possible to turn off the router bit and put thing into modem only (bridge) mode.
To work out which is the best strategy for you, tell us the modem number of your modem.
