Obiwan_
Apr 14, 2018Apprentice
Speed Test on Nighthawk app doesn't work
I have two R7900P routers at one location. I installed the Nighthawk app and see some use. App Version 2.13.325 Firmware v1.3.0.11_1.2.2(Test)
The one thing I noticed is that the Speed Test doesn't work. It is the Okla based speed test that I have installed on my phone (Samsung S8). The Okla Speed test on my phone works great. If I run the speed test on either router with the Nighthawk app, it says "COULD NOT CONNECT". Anyone have the SPEED TEST portion of the app work?
1 Reply
- RosaleneAspirant
I have exactly the same problem It did for a while but now says it cannot find the router and I should reboot - which I have nod to no avail re the speedtest. Minor but annoying.
