Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDR3400 and Netgear Genie
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-06-30
05:42 PM
2014-06-30
05:42 PM
Can someone please explain to me why NetGear Genie doesn't connect to my NetGear WNDR3400?
I am assuming I enter the same password as I do when logging on via the older internet-based interface? (Although I have tried using just the standard password, too, with no luck.) Genie always tells me it failed to log in and the connection timed out.
Any help out there, please?
Thanks.
Message 1 of 8
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-01
02:26 PM
2014-07-01
02:26 PM
Re: WNDR3400 and Netgear Genie
Not sure. Works for me.
Are connecting by ip address? if not try that.
Message 2 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-02
12:59 PM
2014-07-02
12:59 PM
Well I was connecting wirelessly via my Android. Is it not supposed to pick it up?
And where do I find the IP address?
Message 3 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-03
09:08 AM
2014-07-03
09:08 AM
When you get the login tab in genie, ther is a check box "enter routers IP address manually".
Check that to enter IP.
Message 4 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-03
11:25 AM
2014-07-03
11:25 AM
Here is the link where you can check the supported routers of Netgear Genie.
http://kb.netgear.com/app/answers/detail/a_id/24686/~/netgear-genie-supported-routers
Message 5 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-06
08:52 PM
2014-07-06
08:52 PM
Thanks for that.
How do I find out which version I have?
Message 6 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-07
05:55 AM
2014-07-07
05:55 AM
Look at bottom of the router.
Since you are asking you likely to have V1.. V1 only will NOT have V# after the model on the bottom of the router
Message 7 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-07
10:34 PM
2014-07-07
10:34 PM
And V1 doesn't work with Netgear Genie...
Message 8 of 8
Announcements
