Reply
Won't connect
Rizzo0849
Won't connect
Model number R6020 bought today plugged in like it says I can only get 3 of the 4 lights to come on
Message 1 of 6
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Won't connect
Hi @Rizzo0849,
1. Please try going through the setup procedure first. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/22697
http://kb.netgear.com/app/answers/detail/a_id/22717
2. You can also try MAC spoofing.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
Message 5 of 6
All Replies
William10a
Master
Re: Won't connect
What do you mean won't connect/
The internet form the modem,by wifi, wired lan and what lights are you saying that come on?
Message 2 of 6
Rizzo0849
Re: Won't connect
I had all the cords hooked up how they are suppose to be there are 4 lights on the front first 3 light up and the fourth don't but if I unplug it and move one of the cords the fourth will light up but not third. My phone says connected to wifi but when I try to do anything then it says not connected. I switched back with my old router and everything works fine idk if I got just got a bad router now or what
Message 3 of 6
William10a
Master
Re: Won't connect
Possible since you said you just get the router you try netgear tech support should be under warrenty or return it to the store
Message 4 of 6
DexterJB
NETGEAR Moderator
Re: Won't connect
Hi @Rizzo0849,
Dexter
Community Team
Message 5 of 6
DexterJB
NETGEAR Moderator
Re: Won't connect
Hi @Rizzo0849,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 4754 views
  • 0 kudos
  • 3 in conversation
Announcements
