- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
"Netgear router is not found or is not supported. Also, no IPv6 is enabled' Windows 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wireless works but no wired internet connection after Windows 10 installed. Up dated Genie and did the work around. Worked for a while on and off. now nothing????
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: "Netgear router is not found or is not supported. Also, no IPv6 is enabled' Windows 10
Hi @Donl1000,
The NETGEAR Genie is only an additional program that will allow you to monitor and make some changes to some settings of your router and should not affect the Internet connectivity of your wired devices.
1. What is the model number and firmware version of the router?
2. Have you tried resetting the router?
3. Have you tried changing ports or cables?
4. have you tried power cycling (turn off and on) the router?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Configuring repeating settings:
- First, you need to connect your wireless router device which you wish to function as the repeater to the computer using the standard Ethernet cable.
- Then, login to the Netgear router by typing 192.168.1.254 ip address in to the address bar of your web browser. Then, press Enter.
- The login page of a router will be displayed on the screen. In the username text box, you have to enter the default username admin and a default password is password. When you have already changed your router device default password, then you have to enter your custom password and then hit Enter.
- In this step, you must have to click on the maintenance -> Router status.
- Note down a value of MAC address displayed on this status screen of your network router.
- Then, connect to a wireless network you wish to repeat.
- Once logged in to your Netgear router, you need to click on the wireless settings.
- Note down the values of 11N channel, Mode, SSID, security encryption key, and also security options fields.
- Click on the advanced and wireless repeating function.
- After that, click on the enable wireless repeating function and then wireless base station.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@petercloud29 Did you mean to post in a different thread?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was this issue resolved by anyone? I have been getting the run around from netgear support for over 3 weeks now. It happens on all my devices. Win7 Win10 iOS Sierra and with different web browsers as well Safari IE Chrome. This is very frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had to upgrade my router from my previous Netgear and used to think Netgear and Genie were great.
I am also having a persistent problem with not being able to log in to my new R7000 with my wired PC.Fortunately I can access from the tablet and the phone and it is working. It appears that there is no resolution for this with people getting a runaround. I have checked EVERYTHING mentioned as others have and am not able to resolve this issue. This is incredibly frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update firmware for router or Modem? I have netgear modem CM700 and I am running into this issue frequently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried power cycle and resetting the router, and tried two delegate computers. I can ping the router on 198.168.1.1 and ping websites like google.com; the wifi is working and says it's connected to the internet but I can't access the internet nor log into the router.
I also tried PeterClouds methods with direct plugging Ethernet into the computer and typing the 198.168.1.245, and that's where the road ends. I loaded the newest firmware but I can't access the router to load it. Help me pls!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I received that message the only thing i wanted to do was to update my router but i can t and i donot want ago on remote. Thanks
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
