Orbi WiFi 7 RBE973
Reply
timing out when logging into r8000p router
JGore
Follower
Attempting to login to nighthawk on phone is giving continous timed out message,.  Deleted, reinstalled and same message.  App keeps telling me to reboot router, which I did once and no help.  Phone is a Galaxy Note 10.
I'm currently logged into Genie on my computer with no issues. Router is runnng and internet is functioning perfectly.
R8000P — Nighthawk X6S AC4000 Tri Band WiFi Router
Should I be worried that this product is not even listed above?
Message 1 of 2
Re: timing out when logging into r8000p router
Is this with a local wifi connection or through remote access? Set up on MyNetgear?
Any oddities on the network? R8000P in AP mode?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Just Netgear being lazy about updating its database of devices.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 747 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
