Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
ABSOLUTE TRASH mr80 and the app
THEbarbarian87
To the day when the armor trial expired. Poof my settings changed. Internet would crash every 24 hours. Factory reset is failing completely. This is the biggest piece of **bleep** mr80 and 2 ms80s
Message 1 of 2
Guru
Re: ABSOLUTE TRASH mr80 and the app
Why is factory reset failing?
What error is it giving you?
Are you using the reset button? You push and hold it for 7-15 seconds while the device is powered on?
Or are you going through the gui menu for reset?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 342 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
