Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Any easy way to connect 2.4GHz only devices ?
ssartor
Hi,
I have a Nighthhawk AX1800 Mesh WiFi System (MK63S) which works really well.  Recently, though, I tried to set up an indoor security camera that only connects on the 2.4Ghz band and was unable to do so.  Because this is a mesh system there's no ability to turn off the 5Ghz radio and i see no way in the software to force a connection to a specific band.  Is there any (easy) way to connect a 2.4GHz only device?
thanks for any help
Message 1 of 4
Guru
Re: Any easy way to connect 2.4GHz only devices ?
Turn OFF the MS. Try changing the power output of the 5Ghz radio to 25% on the MR. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Message 2 of 4
ssartor
Hi,
I'm running my MR60 in AP mode with firmware V1.0.6.116_2.0.54 and I don't see any option to change the power level of the 5GHz radio.  Under Advanced Setup=>Wireless Settings i can change the CTS/RTS Threshold for both 2.4 and 5GHz radios, enable 20/40 MHz Coexistence for 2.4GHz, change the Preamble, enable SSID Broadcast, enable Implicit Beamforming and enable AX.  And that's it -- not a lot to tweak.
thanks
Message 3 of 4
Guru
"enable SSID Broadcast" <Disable this.
Message 4 of 4
Discussion stats
  • 3 replies
  • 1323 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
