- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
App speed check does not display speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
mesh 6 router with two satellites MR 63 . Net gear app on my iPhone and iPad. Speed check runs but does not display speeds, only says I have moderate speed.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All of a sudden it has now working just fine. I have no idea why.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: App speed check does not display speeds
when you run it off a device and not off the netgear app, does it work?
its a more trustworthy test anyway
- Mark as New
- Bookmark
- Subscribe
- Permalink
Other speed checks work, I've tried removing the app and putting it back in on both iPad and iPhone. Rebooting modem and router. All firmware is up to date so I'll told. All other functions on the app work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what modem/gateway is the MK system connected to
- Mark as New
- Bookmark
- Subscribe
- Permalink
My modem was supplied by spectrum/charter is a Hitron E31N2V1. Should I replace it with my own modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No. I was just making sure you weren't in a double nat. It can cause issues. You're not.
Does the speedtest work if you go through the router's browser?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't think I know how to do that. Technolology has left me behind. I just used the app to setup the new mesh system haven't actually gone into the router. Just got it a Costco last week. They had hundreds for sale, seems like others would be having this same problem.Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'd be surprised at how frequently something in the app doesn't work.
Everything else works fine though?
and the speed test on individual devices is hitting the speeds/performance?
If so, I wouldn't worry about it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No problem , I have other ways to check speed. Thanks 76
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Strangely I love when things fix themselves.
If you mark it solved, it might keep others from trying to fix a solved issue 😉
