Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Connect Nighthawk Mesh WiFI AX1800 to existing Wifi network (as a repeater)
Praveenpp
Follower
Is it possible to connect Nighthawk Mesh WiFI AX1800 to existing Wifi (as a AP/Bridge/Repeating Mode) instead of connecting LAN directly into the base unit. I want to do this to extend the reach of my Wifi Mesh.
Message 1 of 3
schumaku
Guru
Re: Connect Nighthawk Mesh WiFI AX1800 to existing Wifi network (as a repeater)
No.
And it's perfectly fine that it isn't possible,
On an Ethernet cable, you can reach a distance of 100 meters for Gigabit (even 2.5, 5, or 10 Gb is feasible) in a reliable way.  If you need longer distances, even fiber installations are feasible. From the points where you have real wired network, you cold deploy wireless access points - again wired - for the
On a wireless "hop" of such a Nighthawk Mesh you barely get a fraction of the performance _and_ the distance. Waste of bandwidth (on-air - bandwidth is limited by the small number of channels).
Anything else was born in the dreams of "mesh" marketing people: The bi- or tri-annual rat-race for having to update to the "latest" Mesh system is already waiting behind the door again.
Message 2 of 3
Guru
Netgear has set up a community forum specifically for the Nighthawk MESH product. Most of the people who watch that forum are more likely to have experience with Nighthawk MESH and know how to work it better than those of us who follow this "Orbi AX" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1280 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
