Hvidegaard's avatar
Mar 10, 2021
Devices not listed in network map in app after wired sattelites
Hi community
I am new here. I have the Nighthawk wifi6 mesh system MK63.
Having wired the sattelites for better performance (Or actually even working as intended) my devices connected to the wired sattelites suddenly can't be seen in the Nighthawk app.
The device (e.g. my phone) is on wifi and working but it doesn't appear in the network map on either the router og any of the 2 sattelites.
Have anyone experienced similar?
Best regards, Peter
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Peter,
    May you reinstall the Nighthawk app and check to see if you're able to see the connected devices from the admin page via web browser at routerlogin.net.
    Thanks
    Christian
    • Hvidegaard's avatar
      Hvidegaard
      Tutor
      Hi Christian,
      Thanks for your reply.
      I have tried re-installing the app as suggested. However, no change in result.
      Yes, I see the device on router login.
      Actually I can also see the device in the app.................
      Looking at the Network map
      On the wired sattelite "No connected Device found"
      Looking at the Device manager
      The device appear in the device manager
      However: Pushing the individual devices, On devices NOT CONNECTED to the wired sattelite (That is the router or the wireless connected sattelite) it states in the top of the device "Connected to sattelite/router name 2,4/5 GHZ wifi"
      On devices connected to the wired sattelite this line doesn't exist
      ???????????? In general there seems to be some kind of communication issue between the router and the sattelite in the Nighthawk system. I have struggled with multicast broadcasting related to Sonos which has never been solved
      Really hoping for any kind of help
      Best regards
      Peter
