Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Does routerlogin.net work over ethernet?
NathRao78
[I still cannot put in MR60 as the router model.]
On the desktop connected to the router by ethernet, when I try putting in routerlogin.net as the address it goes to Netgear website. That says that I must be on the same wifi network as the router. Does this mean that the router does not recognize the address if it comes via ethernet port? I thought it worked last year when I got the router. [It does work over wifi on laptops.]
Thanks in advance
Nath Rao
Message 1 of 2
Guru
Re: Does routerlogin.net work over ethernet?
what modem/gateway is the router connected to?
Have you tried using its ip address? The default is 192.168.1.1 but if you changed it or are in a double nat, it could have changed.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 772 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
