Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Firmware update not showing in auto-update
in2ndo
Apprentice
Hello everyone,
I just bought and installed a Nighthawk MK83 / 3600 router .  current version on the rounter web page and iOS app.  is V1.1.4.6 and version on the negear site 1.1.5.4 .
Is there a reason for this?  I've run the check on the router's webpage and the iOS app and it says there is no update. I know I could download them and do it manually I guess.  but I'm trying to avoid that. to not create possible problems.  and I think if there is an update available. it should be happening automatically if that is how the router has been set up.
Thank you.
Message 1 of 6
Accepted Solutions
Guru
Re: Firmware update not showing in auto-update
In my experience on here, if you're hardwired in, the manual update has less errors/corrupt firmware issues.
It tends to be when it auto-updates, when done over wifi, or when done via the app that we see corrupt firmware issues.
its why its one of the most frequent recommendations (manual update over hardwired connection)
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 6 of 6
All Replies
Guru
sometimes the manual update server sees/gets the update before the auto update server.
You can manually update. If you do so, update the satellites first, then the router.
Message 2 of 6
in2ndo
Apprentice
That did cross my mind.  but since June? doesn't netgear have a computer set all this up?  or someone uploads them to the different servers manually. ... LOL.
Message 3 of 6
Guru
what modem/gateway is it connected to?
I've seen times where a double nat causes the auto-update not to function properly
Message 4 of 6
in2ndo
Apprentice
Thanks for the reply.  the modem is from spectrum cable.  and is a plain modem.  doesn't have routing capabilities.  I just did the manual update and went smoothly.  hopefully I wont have to do that again.  by experience.  the manual updates tend to have issues more often.
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1819 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
