Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Having Issue with MS80 Satellite (Dropping Speeds) (MK83)
Akomix
Guide
Just setup my MR80 Router and two MS80 Satellites a couple of days ago.
Noticing quite a few issues with the satelite I have hardwired to my desktop. Generally, I'm getting 230 Mbps through the Satellite. However, after some time P2P downloading, I'm getting 10 Mbps on every device connected to the satellite. This is persistent until I reboot (sometimes doesn't fix) or change a setting at the router (again, sometimes doesn't always fix).
Firmware: V1.1.5.4_3.1.91
20/40 MHz Coexistenec is Unchecked
Preamble Mode: Short
SSID Broadcast, BEAMFORMING, MU-MIMO, Enable AX are all enabled.
After some exhaustive searching it seems no one has a good solution for this other than returning, so I wanted to ask here before returning. I've always used NETGEAR products, but so far this is leaving a lot to be desired.
Message 1 of 7
Guru
Re: Having Issue with MS80 Satellite (Dropping Speeds) (MK83)
A couple things you can try.
1. upgrade the MS80 to version 1.1.6.4
2. unless you live in the country with no one around like coexistence checked.
3. try a factory reset/reinstall of the satellite
It only happens to the satellite?
And the hardwired connection drops as well?
Everything with the router stays fine?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 7
Akomix
Guide
Thanks for the response.
I'll upgrade the firmware, but I'm not super hopefull it will help.
Yes, it only happens at teh satellite itself, still full speed at the main router and other satellite. I tried swapping satellites and it still happened. Yep, both hardwired and wireless connection drops to an abysmall speed. Yep, everything at the router is A-okay when this happens.
EDIT - wanted to add an update and say my internal network speed also plummets into the low KB/s range while this is occuring.
Message 3 of 7
Akomix
Guide
Just as another update,
I've discovered that this doesn't just occur when utilizing P2P connections. This occurs regardless after an extended period of time. It is still only affecting 1 satellite when it occurs (conveniently mine) and still requires a reboot at the Router to rectify and get back to full speeds.
I have another MK83 set today and am going to swap everything and see if that fixes it. If not, I'll have to look at a different solution. Restarting the router everytime this happens is not ideal.
Message 4 of 7
Guru
so the internet network speeds go down but you also put the router runs fine.
Which is it?
Message 5 of 7
Akomix
Guide
I don't think I ever mispoke. The speeds from the one satellite are the ones dropping and not just internet, also internal network speeds stemming from this satellite. The speeds from the router itself have been fine as I can run the speedtest from the router, and my phone connected to it, and it gets full speeds. However, it still requires a router reboot to restore the slow speeds affecting the satellite.
I tried swapping satellites from the one I have in the basement and it failed to stop this from occuring.
Message 6 of 7
Akomix
Guide
Just as an update. I ordered a replacement set of router and satellites. Once the new set was installed I haven't had the issue happen again; which may point to an original faulty set I had.
Fingers crossed for smooth sailing from here.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 497 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
