- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvB...
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT...
According to their support the fix should come in next firmware, in between you can try this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is a few updates back from the curret one, so it used to work before? I never had it work fo me for the last year... See what happens...
Current Firmware Version:
V1.0.6.116_2.0.54
Uploaded Version:
V1.0.6.103_21.3.3
- Mark as New
- Bookmark
- Subscribe
- Permalink
The instructions say do ROUTER first the SATILITE on the ADMIN update page - why ackwards?
- Mark as New
- Bookmark
- Subscribe
- Permalink
WOW! Everytime I update them (AND I have disabled auto firmaware update and Applied) somehow they ALL keep updateing back to v.116 , I cannot keep the router or the satilites (2 each) on the v.103 for the FW, they keep updateing back to v.116 eventhough I have auto disabled.
It just keeps getting better, I really need to just throw these away and invest in the Eero ones, I see they work with Apple Homekit too. Better App from what my friend shows me too. Cut my loss and lesson learnend with Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I downgraded to this yesterday and my homepods have worked perfectly since, thanks for sharing!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you happen to have a upstream router by chance in front of the MR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just installed version 122 today, which includes in the release notes "Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60." So far its been working!
MR60 (Mesh Router) : https://www.downloads.netgear.com/files/GDC/MK62/MR60-V1.1.6.122_2.0.58.zip
MS60 (Mesh Satellite): https://www.downloads.netgear.com/files/GDC/MK62/MS60-V1.1.6.122_2.0.58.zip
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for this. Unfortunately it hasnt resolved my issue. Back to the drawing board. I'll look into roling back the firmware I think.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you upgrade the Satellite first? In my circumstance, I have the Satellite connected wirelessly. I have one Homepod which is close to the router and a Homepod mini close to the Satellite. Airplay would work intermittently to the HomePod but never work for the Homepod mini. If I turned off the Satellite, I could get Airplay to work with the downside that wifi coverage didn't extend through to all rooms it needed to. Seperately, I also have an AirPrint capable printer that would only work with the Satellite disconnected.
With this latest firmware, both Airplay and Airprint work with the Satellite powered on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also today I saw that AirPlay to a printer won’t work either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to factory reset the MS and MR and setup from scratch after upating FW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DariosaurusRex wrote:
How did you update the software.
- Mark as New
- Bookmark
- Subscribe
- Permalink
On my side, it seems that the new FW has fixed the issue with Homepod mini.
I will monitor this in the coming days, but for the first time I could transfer music from my iPhone to the Homepod mini
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have just updated my satellite and router to Version 1.1.6.122. Haven't been on here in a few weeks, but I spent over an hour on the phone with netgear stupport essentially helping them collect logs and bug fix. They then sounded pissed off when I wasn't able to answer the phone during the work day! To top it off they called multiple times on Thanksgiving day 😕
Going to see if Version 1.1.6.122 fixes things. Does anyone know of a good way to check if the homepod minis are connected to the router or the satellite? For me that would be the critical test to show it's working, but as of now I don't know how to verify if they're connected to the router or satellite. Thanks!
Greg
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ive tested V1.1.6.122 for a few days. It does make the Airplay system work with multiple homePods but it has introduced a new issue.
Normally when you say "Hey Siri" and you have two or more homepods within earshot, the one that picks up your voice the clearest takes the command.
THis update now causes all homepods (within earshot) to execute the command indepentantly - for example, if you said "Hey Siri play some music", both homepods would each start playing random music.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe space the homepods farther appart?
- « Previous
- Next »
