Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
How to use 5Ghz band on MR60?
perry227
Follower
I have an MR60 mesh system and I'm trying to get my Macbook Pro to connect to the 5 Ghz band. I have some programs that need that and the laptop only connects to the 2.4 Ghz band by default. How can I get it to connect to the 5 Ghz band?
Message 1 of 2
schumaku
Guru
Re: How to use 5Ghz band on MR60?
Beside of the maximum available speed, there is no logical difference if using 2.4 or 5 GHz radio for the connection - everything connects to the very same network.
Why do you think the MBP does not make use of the 5 GHz band?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 652 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
