- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is Mesh Wifi compatible with AirCard Smart Cradle?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I have a Netgear AirCard Smart Cradle with Telstra mobile 4G Wifi fitted - which holds the sim card.
For some reason in last 3 months the wifi just stopped reaching throughout my home - which was previously OK with a Netgear extender (WN3500RP).
I was researching Mesh Wifi which looks like it might be helpful, however I can't find how (or if it is possible) to connect this with existing wifi. The installation instructions only refer to connecting to a modem that connects to a wall plug.
We don't have ADSL or NBN. We just have 4G wifi.
Can the Nighthawk Mesh System (MK63) connect into the Smart Cradle to use the Telstra Wifi?
Thanks in advance!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry, typing to fast. The DC112A cradle (if thats what you have) should have ethernet ports to connect the MK system to.
If the aircard is in router mode though, you'll need the MK system in access point mode. Or you'd need to put the aircard in passthrough mode
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is Mesh Wifi compatible with AirCard Smart Cradle?
the smart cradle should have usb ports on the back of it to connect devices to it.
You should be able to connect the MK62/3 system to it with the mk60 router ran in access point mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for taking the time to respond, however although the cradle does have a USB port, the MK63 router doesn't have any USB ports. I'm not sure that it is possible to connect USB to Ethernet port
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
