- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MK62 with switch for backhaul and ethernet clients
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can I use an unmanaged switch as both ethernet backhaul to MS60 satellites and wired ethernet clients as pictured below? Is there any advantage of doing this over just using a router and Netgear WAX214 access points with identical SSIDs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MK62 with switch for backhaul and ethernet clients
@TimNetGeek wrote:
Can I use an unmanaged switch as both ethernet backhaul to MS60 satellites and wired ethernet clients as pictured below? ---yes you should be able to do this . I do it frequently (not the MK60 series but other orbi series) Is there any advantage of doing this over just using a router and Netgear WAX214 access points with identical SSIDs?----It should perform pretty similar if using a wired backhaul. The WAX will have a few more business oriented features but if you don't use them, they should perform about the same.
