- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MK63 satellite reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello - I am resetting a whole mesh network composed of MK63 router and satellites. It is reported in another thread, but I thought to do a dedicated thread for a specific issue I am having.
The issue is with the password of one satellite, which I need to use to do FW upgrade of the satellite.
I did a factory resent and re-synced the satellite but it seems that its password is not the default "password" and is not the one from the router.
Has anyone had a similar issue?
Many thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MK63 satellite reset
Try hardwiring it into the router and re-syncing it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK this worked, thanks. Note that after re-syncing some times the password is the one from the router and some times is the default one.
