Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR 60 Support Call and apparent followup
Barry9323
Follower
So just made my first call to MR60 support to get my Satelite working again.  They called me znd I went to SOS.Splashtop.com.  The accessed my system and got me working. unplugged satelite and put in other area and waited for it to work.  Went back to computer and found my new SUPPORT BUDDY perusing my internet history.  Felt real creepy and out of line. I sincerely believe if I ever need their support again I will get different...NON netgear equipment.  At least I had this place to vent.
Message 1 of 2
Guru
Re: MR 60 Support Call and apparent followup
You may have been contacted by a false an fake person. NG will never ask you to put remote controlling apps on your PC. No NG would not refer to you a 3rd party support site.
I recommend you unistall what was installed and do a full malware scan of your PC.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 277 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
