- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MR60 Amber light - MS60 blue light
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a MR60 with three satellites. The MR60 router is showing an amber light while the satellites have blue lights. The satellites have internet access. The MR60 however is not showing on the network as connected and I am not able to connect to the ip address. I have tried the DNS configuration mentioned on a previous post, but can't access the device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MR60 Amber light - MS60 blue light
What does the user manual say about LED color indication?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well I can't log into the device to find out the firmware version, but I know its not the latest. Amber lights mean it is not connected to the Internet. I have the router setup as an Access Point, connected directly to my Xfinity Router. The Xfinity rounter doesn't show it as a connected device, but the Xfinity connected app shows being connected. All the Satelittes have blue lights and internet access.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the XF app show an IP address for the MR in AP mode?
When you set up the MR in AP mode did you use Dynamic IP address or Static IP address configuration on the MR? Static is recommended so you know the IP address of the MR in AP mode all time and it doesn't change.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes it shows on the XF rounter with a static IP address, which is how I set it up. It does show as a device not connected, but IP address reserved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you use IP address reservation ON the ISP router or did you set a Static IP address on the MR in AP mode?
Static Address differs from IP address reservations. Static IP address is set ON a device, not a router.
IP address reservation is set ON a router and not set on a device.
