- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MR60 Mesh WiFi 6 Router can't perform factory reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't perform a factory reset on my MR60 router. The LED is blinking white from the moment I power it up. I even performed a 30/30/30 and it won't reset. Any suggestions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just contacted Netgear support. After troubleshooting, they informed the firmware was corrupted. I will be returning it for a new one. Thank you for your help.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MR60 Mesh WiFi 6 Router can't perform factory reset
are you able to log into the device? You can factory reset from within its menu's.
Are you holding the reset for 7-15 seconds while powered on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You don't need an internet connection to log into the device.
with it unplugged from the modem, you can connect a pc/laptop to a lan port and should be able to log into it and make changes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I do that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
with a pc/laptop connected to the MR60, open a command prompt and type ipconfig
the default gateway will be the IP address for the MR60. Try using that to access it.
You can also try the default routerlogin . net
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is no default gateway address and if I use routerlogin.net, it takes me to my modem/router login.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If its taking you to the modem/router gateway's address, the mr60 is functioning. Did you put it in ap mode?
If so, check in the modem/gateways connected devices page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
good luck with the next unit
- Mark as New
- Bookmark
- Subscribe
- Permalink
During the initial installation of my MK60S (MR60 + 2 MS60 Satellites), the firmware update bricked my MR60 router. Factory resets, including the 30-30-30 (hold reset button in for 30 seconds while router is powered, then while continuing to hold reset button disconnect power for 30 seconds and finally, while still holding in the reset button, power back on and release reset button after 30 more seconds) failed to re-establish the original SSID so I could not wirelessly connect to the router. I discovered that I was able to ping the router at 192.168.1.1 by connecting my PC to the LAN port and setting a static IP address on my PC to 192.168.1.10, subnet mask to 255.255.255.0 and Gateway to 192.168.1.1. However, that was all I could do. Called support and they had me download a TFTP program and the latest firmware file. Was able to use the TFTP program to push the new firmware to the router which fixed my problem. The article the tech referenced can be found here:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
