- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MR60 - Not able to access Twitter?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just purchased the nighthawk mesh and installed it. Works great. Newest firmware (1.1.6.124) uploaded today. But I cannot access Twitter. At all. I haven't found any other website with issues. It doesn't matter what browser, computer, device, etc. When I connect to a different wifi signal, Twitter works normally no problems at all.
Can anyone help me troubleshoot this problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MR60 - Not able to access Twitter?
Armor, Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what error do you get?
Do you have IPv6 enabled?
Have you tried a different dns provider for both ipv4 and ipv6?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem is Comtrend VR-3060
The Armor and Traffic Meter are disabled, but I don't have a "circle" to turn on or off.
I've tried new DNS, I've enabled IPv6, etc.
Plugged, unplugged, rebooted, etc.
I'm on Windows 11 on a Microsoft Surface tablet. It loads an error. My husband is on a Chromebook and it loads perfectly every time. We're on the same network.
I've turned off all my browser extensions. I've tried Edge and Chrome. I can use my phone to access the app, so it's not a Twitter account issue.
I'm about to give up on this system. I'm a social media marketing student, I HAVE to have access to Twitter on a regular basis!
- Mark as New
- Bookmark
- Subscribe
- Permalink
The comtrend is a modem/router combo device. It causes a double nat. Usually isn't a major issue but it could be causing your problem.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-M...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router function was never enabled on the modem. When it was installed the tech used our old (circa 2016? Maybe older?) Netgear router, which had been functioning well with the old cable internet we'd had. When we upgraded to faster internet with another company I wanted to upgrade our router and went with the MESH so it would reach areas in our house that were usually dead zones. While on the old Netgear router, with the ComTrend modem, I could access Twitter like normal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you check your comtrend or just trust that its in bridge? and that the bridge function is running appropriately?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know how I would do that without connecting it to a device, but I don't have an ethernet port on my Surface or my husband's chromebook. It's not broadcasting any kind of wireless signal that I can find, so I'm sort of left to assume that all the router functions are disabled.
