Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR60 Xfinity Gateway Died…new modem, but no internet cabke recognition on MR60
Mwatson
My xfinity gateway died. Got a new gateway, hooked it up, but the MR60 reported no ethernet cable was plugged in. Tried dufferent cables, no change. Tested gateway ethernet ports, they are working. Bought a new cable modem, same problem, ugh, must be the MR60.
Have done factory reset on MR60. What other diags can i try?
Message 1 of 6
Guru
Re: MR60 Xfinity Gateway Died…new modem, but no internet cabke recognition on MR60
What actual modem/gateway did you buy or are you trying?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 6
Mwatson
I have tried 2:
I got another gateway from XFinity, same model as the last one, (running it in bridge mode), but the MR60 doesn't see the ethernet cable in the Internet slot.
I also bought a NetGear CM2050V, because I wanted to get rid of the rental fee for the Xfinity gateway.  Same issue, MR60 doesn;t see the cable plugged in.
I have swapped cables.  I have done a reset.  Not sure what else to try.
Message 3 of 6
Guru
Is the Mr60 still in warranty?
Click on "mynetgear" at the top. register an account and the device.
You should be able to check warranty status there
Message 4 of 6
Mwatson
Definitely out of warranty as I puchased it in May 2020. :-(.
Is there any kind of hard reset I can do that might bring the port back?  I've done the reset via the pinhole on the back, holding it down for 15 secs.  Perhaps there is something else I can try?
Message 5 of 6
Guru
I don't have that model but in some of the nighthawk and orbi models there was a wan port mirroring option.
go to its ip address plus /debug.htm
so if your ip address is 192.168.1.1 you'd go to:  192.168.1.1/debug.htm
See if it has that option. maybe you can mirror your wan port to lan port 1
maybe @Christian_R knows of some other tricks with that model Smiley Happy
You could also try reinstalling the firmware or downgrading the firmware in case something was corrupted.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 347 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
