- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MR60 slow LAN speeds by over 60%
- Mark as New
- Bookmark
- Subscribe
- Permalink
When plugged into the MR60 I'm getting approximately 330 Mbps.
When plugging the same cable into the Fios router it's 900 Mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MR60 slow LAN speeds by over 60%
What fios router are you connecting it to?
How are you testing speeds? (what device, website, app, etc)
Are you testing wired speeds? Wireless speeds?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Testing Lan internet speeds using pc with GB Lan card. Tested using fast.com and speed.cloudflare.com, wired speed is 330 Mbps on the MR60 and 900 Mbps when plugging the same cable into the Fios router.
Wireless speeds are about 450 Mbps depending on the laptop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For context, the first speed test is direct into the Fios router, the second is the same cable plugged into the MR60 LAN port. It wasn't always slow, I'm assuming a firmware upgrade is causing this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make sure on the MR60 that you have access control, traffic monitoring, qos, and parental controls disabled, then reboot it and try.
Is the fios router in router mode or passthrough mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Somehow QoS was turned on, I turned it off and now I'm getting about 600 Mbps which is much better but I also signed up for a free 30 day trial of smart parental controls, it doesn't appear that there is a way to turn it off, but it expires on 5/10/22 so hopefully tomorrow I see a difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If that doesn't help, 2 things.
1. factory reset and reinstall. leave those services disabled
2. check to ensure the g1100 is in passthrough mode. otherwise you could be in a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-M...
